Globally, allows untagged ports to be moved directly from untagged VLANs to either different untagged VLANs or tagged VLANs.
on | Auto-move global setting is on, which allows you to move untagged ports from untagged VLANs without first removing the port VLAN configuration. |
off | Auto-move global setting is off; you cannot directly move untagged ports from untagged VLANs without first removing the port VLAN configuration. |
inform | Auto-move global setting is on, but you are informed when such a move occurs
(default):
Port # untagged has been auto-moved from VLAN "x" to "y". |
The default is inform.
Moving tagged ports is not impacted by this global setting. You can move tagged ports directly without having to enable the auto-move global setting.
The following example turns on the auto-move global setting:
configure vlan untagged-ports auto-move on
The following example turns on the auto-move global setting with the inform option:
configure vlan untagged-ports auto-move inform
When the inform keyword is used, you can directly move an untagged port, but you are informed that this has occurred:
configure vlan untagged-ports auto-move inform configure vlan v2 add ports 1 untagged
Port 1 untagged has been auto-moved from VLAN "Default" to "v2".
This command was first available in ExtremeXOS 22.1.
The default was changed from off to inform in ExtremeXOS 22.4.
